Hardware Compatibility
Magewell XI400DE and HDMI to UTP extender using VMIX
I’m using a Magewell XI400DE card. Between camera and computer I’m using a HDMI to UTP extender http://www.allekabels.nl...er-hdmi-verlenger.html). Using this combination VMix gives an error: unsupported input signal. As I connect a Magewell XI100DUSB between the HDMI to UTP receiver, it works well. If I use the HDMI to UPT extender between a camera and an ATEM it works well and between a camera and monitor. Do someone having experience with this combination? Or what kind of extender I had to use in combination with the Magewell XI400DE.
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
hello erik, what kind of signal do you send:1080p25 ? or something else? is there a way to check what comes out of the hdmi - utp - hdmi conversion? so what will go into your magewell card.
greetings stefan
ps i have switched from utp to wireless using the fantastic nyrius aries pro with up to 30m line of sight connection with 1ms delay. for longer distances i switch to using sdi, since this is more reliable...
Hello Stefan,
I have tried a lot of settings and combinations but it won't work. It's not a problem of vMIX because another captureprogram didn't capture too. SDi seems to be a solution.
Greetings, Fred
