Joined: 4/12/2020(UTC) Posts: 11  Location: London Thanks: 2 times
[1] After working fine for some months with either Skype or Zoom set to NDI, suddenly I have audio but a black screen. What could the issue be?
[2] If I select vMix Video as the source in Skype or Zoom why do I see only a test card and not my output?
Thank you for any help you are able to give.
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Quote:Skype or Zoom set to NDI, suddenly I have audio but a black screen. What could the issue be? ??? Could you elaborate a bit? As explained, it's impossible for us to understand what you're doing ! Black screen? Where ? In vMix or in Zoom/Skype? Zoom does not support NDI by default so what is your workflow ? Quote: If I select vMix Video as the source in Skype or Zoom why do I see only a test card and not my output? As already explained a hundred times in this forum, as indicated in the manual, you must activate external out
