davenv
#1 Posted : Saturday, December 26, 2020 2:24:24 AM(UTC)
davenv
You have been a member since:: 4/12/2020(UTC)
[1] After working fine for some months with either Skype or Zoom set to NDI, suddenly I have audio but a black screen. What could the issue be?
[2] If I select vMix Video as the source in Skype or Zoom why do I see only a test card and not my output?
Thank you for any help you are able to give.
#2 Posted : Saturday, December 26, 2020 2:58:03 AM(UTC)
??? Could you elaborate a bit? As explained, it's impossible for us to understand what you're doing !
Black screen? Where ? In vMix or in Zoom/Skype?
Zoom does not support NDI by default so what is your workflow ?
As already explained a hundred times in this forum, as indicated in the manual, you must activate external out
