watchfulone
#1 Posted : Sunday, November 27, 2011 10:10:10 AM(UTC)
watchfulone
Was thanked: 17 time(s) in 14 post(s)
thanks you again for the awesome work you are doing with vMix very good as usual
I have a bit of a problem I hope you can help me with
I recorded an event for my Church "Rejoice 2011" last month, in the middle of the program the system freezes up and stock i had to do a manual shut down and reboot, I didn`t get to stop vmix recording.
When I reboot and restart vMix i finish recording the rest of the event but when i am ready to edit the footage the file could not be played on anything player i used. VLC, WMP, DivX, Etc. And would work in any of the NLE editors i use Avid Studio, Premiere Pro, Sony vegas, Etc.
Not even in vMix.
Any suggestions how to fix this damage file 40Gb worth of footage gone to waste?
ELCHAPIN
#2 Posted : Sunday, November 27, 2011 2:44:47 PM(UTC)
ELCHAPIN
this option is enabled to have it proved necessary
to avoid accidents.
in google you found a soft. for this
seeketh to re-upload it.
explain the best solution, option
Unfortunate what happened, I use DV caseth for backup, to avoid surprises,
if something does not work properly on the computer
#3 Posted : Monday, November 28, 2011 5:15:40 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
What Codec did you select for the 40GB recording? Depending on the codec used it may be possible to recover the video.
Luc Henrion
#4 Posted : Monday, November 28, 2011 9:22:19 AM(UTC)
Luc Henrion
some freewares available for recovering video files:
http://www.geckoandfly.c...-data-recovery-software/
