How to repair a damage vMix file footage is in avi
Joined: 11/15/2010(UTC) Posts: 99  Location: Jamaica Thanks: 23 times Was thanked: 17 time(s) in 14 post(s)
thanks you again for the awesome work you are doing with vMix very good as usual I have a bit of a problem I hope you can help me with I recorded an event for my Church "Rejoice 2011" last month, in the middle of the program the system freezes up and stock i had to do a manual shut down and reboot, I didn`t get to stop vmix recording. When I reboot and restart vMix i finish recording the rest of the event but when i am ready to edit the footage the file could not be played on anything player i used. VLC, WMP, DivX, Etc. And would work in any of the NLE editors i use Avid Studio, Premiere Pro, Sony vegas, Etc. Not even in vMix.
Any suggestions how to fix this damage file 40Gb worth of footage gone to waste?
Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
this option is enabled to have it proved necessary to avoid accidents. in google you found a soft. for this seeketh to re-upload it. Martin explain the best solution, option  Unfortunate what happened, I use DV caseth for backup, to avoid surprises, if something does not work properly on the computer
What Codec did you select for the 40GB recording? Depending on the codec used it may be possible to recover the video.
Martin vMix
Joined: 2/6/2011(UTC) Posts: 79  Location: Belgium Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
