visualsuplex
#1 Posted : Thursday, December 17, 2020 7:12:43 AM(UTC)
visualsuplex
Ok - here's hyper-specific issue I've ran into...
I'm trying desktop capture two explicit programs (instead of a single Screen Capture input), Photoshop and Lightroom, so I can program the transition between the two with Companion (along with other actions)
The issue I'm running into is with Lightroom:
a) I need to run Desktop Capture in WindowsGraphicsCapture because vMix won't see any images or panels in the software.
b) Once I select WindowsGraphicsCapture, the input for Lightroom only freezes up and doesn't update. (If I select default it's responds like normal, but doesn't show and images)
c)Photoshop works fine with WindowsGraphicsCapture, and both work fine as a Generic Desktop Capture (with WindowsGraphicsCapture selected)
Anyone run into this with local capture before?
ALSO - the main reason I'm running two inputs is I can't figure how to program a shortcut or a companion action to select a specific source for a single Desktop Capture. For example, you can right click that Desktop Capture input and change between capture sources like screens, or software. Is there a way to program that selection?
