lestra
#1 Posted : Thursday, December 10, 2020 11:06:07 PM(UTC)
lestra
Saint Kitts And Nevis
Hi. I come across this post
https://dev.to/xreyrober...-converter-on-macos-10eb
It is about making second instance of NDI Scan Converter on MacOS and I got idea to try it with NDI Webcam Input (Virtual Input). But...
Using HxD hex editor to edit exe file (copy), I was able to change application name from Network Webcam to Network Webcan (it has to be the exact same length) and after saving it now I can load second instance of application. It works but both instances present in programs menus as NewTek NDI Video and conflict each other.
Any sugestion?
