NDI
Multiple Instances of NewTek NDI Webcam Input (Virtual Input)
Joined: 12/16/2019(UTC) Posts: 86  Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Hi. I come across this post https://dev.to/xreyrober...-converter-on-macos-10ebIt is about making second instance of NDI Scan Converter on MacOS and I got idea to try it with NDI Webcam Input (Virtual Input). But... Using HxD hex editor to edit exe file (copy), I was able to change application name from Network Webcam to Network Webcan (it has to be the exact same length) and after saving it now I can load second instance of application. It works but both instances present in programs menus as NewTek NDI Video and conflict each other. Any sugestion?
NDI
