fabfab10
#1 Posted : Wednesday, December 9, 2020 2:25:01 AM(UTC)
fabfab10
Italy
When using broadcast cameras usually audio channels are used as mono to be fed with mics (ambient mics or separate lavalier mics for example).
In Vmix you can "mono" them using the channel matrix but i haven't found a way to control their audio channels separately, volume slider and on/off button at least.
Peter1000
#2 Posted : Wednesday, December 9, 2020 7:37:02 PM(UTC)
Peter1000
Switzerland
Was thanked: 87 time(s) in 67 post(s)
this is already build in.
go to your input settings -> Audio Settings and choose separate Mono
e voila !
two faders
separate mono.JPG (76kb) downloaded 0 time(s).
fabfab10
#3 Posted : Monday, December 14, 2020 11:43:43 PM(UTC)
fabfab10
Italy
Thank you Peter1000 for your reply.
Actually i have explored that setting before!!
This is exactly what i was looking for.
