slxxi
#1 Posted : Tuesday, December 1, 2020 2:00:07 AM(UTC)
slxxi
I would like to have my external Monitor to Diplay the Preview/Output of the Mix2 Input and not show the "Regular Preview/Output".
- Is there a way to change the Fullscreen -> Display1 Output to show the Mix2 Preview/Output instead of the regular one? The only way for me was to Customize the Layout and add the Mix2 as small input while the "Regular Preview/Output" are still big on Top
- I tried to build my own Multiview by adding a blank Layer and then setting the Inputs as Multiview Layers, but in this Situation it directly shows the Output of the Mix2.
Is there a way to also show the Preview of Mix2 when the Input is set as Multiview Layer?
Thanks in advance.
Chris Daum
#2 Posted : Wednesday, December 2, 2020 11:50:47 PM(UTC)
Chris Daum
Germany
hi
activate NDI on Output e.g. Output 2
get Output 2 as Input via add input "NDI"
route your mix to OUT2
Now you have your mix as an Input and can put it in a Multiview
(I couldn´t think of a better workaround for that... if there´s one let me know!!)
elvis55
#3 Posted : Thursday, December 3, 2020 12:19:00 AM(UTC)
elvis55
Switzerland
vMix Tutorials- Using SRT for input and output
