I would like to have my external Monitor to Diplay the Preview/Output of the Mix2 Input and not show the "Regular Preview/Output".
- Is there a way to change the Fullscreen -> Display1 Output to show the Mix2 Preview/Output instead of the regular one? The only way for me was to Customize the Layout and add the Mix2 as small input while the "Regular Preview/Output" are still big on Top
- I tried to build my own Multiview by adding a blank Layer and then setting the Inputs as Multiview Layers, but in this Situation it directly shows the Output of the Mix2. Is there a way to also show the Preview of Mix2 when the Input is set as Multiview Layer?
Thanks in advance.
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
hi
activate NDI on Output e.g. Output 2 get Output 2 as Input via add input "NDI" route your mix to OUT2
Now you have your mix as an Input and can put it in a Multiview
(I couldn´t think of a better workaround for that... if there´s one let me know!!)
vMix Tutorials- Using SRT for input and output
