K-Dawg
#1 Posted : Wednesday, November 25, 2020 3:29:57 AM(UTC)
K-Dawg
In Larix I'm sending a SRT stream to vmix and set the FPS to 30 using grove.
Stream starts out fine and says 30fps on the screen then drops to 15fps everytime.
On iPhone XR using main camera.
Everytime is drops to 15fps and looks choppy. Any ideas on how I can fix this?
#2 Posted : Wednesday, November 25, 2020 3:41:41 AM(UTC)
4G LTE or Wifi ?
Over the internet or same LAN ?
Which resolution ?
Please be specific on context and use case if you want relevant answers ! We cannot guess your workflow !
K-Dawg
#3 Posted : Wednesday, November 25, 2020 3:49:36 AM(UTC)
K-Dawg
Originally Posted by: DWAM Go to Quoted Post
4G LTE or Wifi ?
Which resolution ?
4G LTE or Wifi ? I've been trying both
Over the internet or same LAN ? Switching between both
Which resolution ? 1080x1920
I just noticed that if I set the framerate to 60 it jumps down to 30 and is consistent.
sam602
#4 Posted : Tuesday, December 1, 2020 2:21:32 AM(UTC)
sam602
Trinidad And Tobago
4G LTE or Wifi ?
Which resolution ?
It appears that you sending vertical to horizontal (9:16...16:9) which can cause this.....Try 1920×1080
