SRT
Larix Broadcaster SRT to Vmix. Framerate drops from 30 to 15.
Rank:: Newbie
In Larix I'm sending a SRT stream to vmix and set the FPS to 30 using grove.
Stream starts out fine and says 30fps on the screen then drops to 15fps everytime.
On iPhone XR using main camera.
Everytime is drops to 15fps and looks choppy. Any ideas on how I can fix this?
4G LTE or Wifi ? Over the internet or same LAN ? Which resolution ?
Please be specific on context and use case if you want relevant answers ! We cannot guess your workflow !
Rank:: Newbie
Originally Posted by: DWAM  4G LTE or Wifi ? Over the internet or same LAN ? Which resolution ?
Please be specific on context and use case if you want relevant answers ! We cannot guess your workflow ! 4G LTE or Wifi ? I've been trying both Over the internet or same LAN ? Switching between both Which resolution ? 1080x1920 I just noticed that if I set the framerate to 60 it jumps down to 30 and is consistent.
Joined: 5/8/2019(UTC) Posts: 37  Location: Port of Spain Thanks: 14 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: K-Dawg  Originally Posted by: DWAM  4G LTE or Wifi ? Over the internet or same LAN ? Which resolution ?
Please be specific on context and use case if you want relevant answers ! We cannot guess your workflow ! 4G LTE or Wifi ? I've been trying both Over the internet or same LAN ? Switching between both Which resolution ? 1080x1920 I just noticed that if I set the framerate to 60 it jumps down to 30 and is consistent. It appears that you sending vertical to horizontal (9:16...16:9) which can cause this.....Try 1920×1080
SRT
