pablocontelles
#1 Posted : Monday, November 16, 2020 12:50:00 AM(UTC)
pablocontelles
Is this possible?
In exemple, I create transparent input, with the colour input.
Go to options, multiview and put input1 at the left (camera 1 cropped), input2 at the right (camera 2 cropped also) and input3 at the center (video resized).
Problem, I have 4 cameras, so if I need to choose camera 3 in input1 I can do manually, losing time.
Is there any possibility to do it using shortcuts? I can add shortcuts to previews and cameras for program, but can't get to work using keyboard.
Basically I need that in input1 of the multiview, I could select input 1, 2, 4, or 5 of the inputs windows (they are cameras) (3 is a video) using the keyboard.
#2 Posted : Monday, November 16, 2020 1:19:30 AM(UTC)
Please check the list of possible shortcuts , especially the ones in the overlay section
There are also vMix tutorial videos addressing (creating) shortcuts using control devices ( keyboard is one of those)
#3 Posted : Monday, November 16, 2020 1:52:55 AM(UTC)
@ pablocontelles
Try this Shortcut:
"SetMultiViewOverlay"
where the Value = Index(Overlay#),Input(Input you want to change it to)
pablocontelles on 11/16/2020(UTC)
pablocontelles
#4 Posted : Monday, November 16, 2020 2:29:34 AM(UTC)
pablocontelles
Originally Posted by: IceStream Go to Quoted Post
@ pablocontelles
Try this Shortcut:
yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeees
that is!! Working now ok
Big thanks pal! My mind almost explode trying to get a solution of this problem.
Guest (4)
