Change inputs in multiview with shortcuts?
Is this possible?
In exemple, I create transparent input, with the colour input. Go to options, multiview and put input1 at the left (camera 1 cropped), input2 at the right (camera 2 cropped also) and input3 at the center (video resized).
Problem, I have 4 cameras, so if I need to choose camera 3 in input1 I can do manually, losing time.
Is there any possibility to do it using shortcuts? I can add shortcuts to previews and cameras for program, but can't get to work using keyboard.
Basically I need that in input1 of the multiview, I could select input 1, 2, 4, or 5 of the inputs windows (they are cameras) (3 is a video) using the keyboard.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Please check the list of possible shortcuts , especially the ones in the overlay section Quote: I can add shortcuts to previews and cameras for program, but can't get to work using keyboard. There are also vMix tutorial videos addressing (creating) shortcuts using control devices ( keyboard is one of those)
Rank:: Advanced Member
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ pablocontelles
Try this Shortcut: "SetMultiViewOverlay" where the Value = Index(Overlay#),Input(Input you want to change it to)
Ice yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeees that is!! Working now ok Big thanks pal! My mind almost explode trying to get a solution of this problem.
