sisselogija
#1 Posted : Tuesday, November 3, 2020 11:43:51 PM(UTC)
sisselogija
I'm sure it would be easy to do a version of vMix just for testing that has no license age limits like the trial one. Meaning all the outputs have a big vmix logo overlaid to defer abusing.
Problem is I don't have access to the production machine since I live in a different town, but i need to test different setups all the time.
The Trial version is great but it lasts limited amount of time and using a different email to get a new Trial doesn't seem to work and is utterly cumbersome in the long run.
#2 Posted : Wednesday, November 4, 2020 1:13:01 AM(UTC)
One can use vMix on 2 separate machines with the same key (just not at the same time)
sisselogija
#3 Posted : Wednesday, November 4, 2020 8:25:11 AM(UTC)
sisselogija
Since the production machine is in use pretty much 24/7, that won't help me.
