Joined: 12/6/2016(UTC) Posts: 2 Location: Kuressaare/Estonia
I'm sure it would be easy to do a version of vMix just for testing that has no license age limits like the trial one. Meaning all the outputs have a big vmix logo overlaid to defer abusing. Problem is I don't have access to the production machine since I live in a different town, but i need to test different setups all the time. The Trial version is great but it lasts limited amount of time and using a different email to get a new Trial doesn't seem to work and is utterly cumbersome in the long run.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
One can use vMix on 2 separate machines with the same key (just not at the same time)
Originally Posted by: doggy  One can use vMix on 2 separate machines with the same key (just not at the same time) Since the production machine is in use pretty much 24/7, that won't help me.
