ELCHAPIN
#1 Posted : Friday, November 25, 2011 6:44:38 AM(UTC)
ELCHAPIN
Hello
I have problems mistakenly saved to hard disk
or recording in AVI, MPEG.
Install DELL Desktop computer
well updated everything, but does not record and goes to Internet
I can blend and everything but grbar which is the most important
codeigo send the soft error + via the attached screenshots.
Thanks waiting for your help
Hola
tengo problemas por error de guardado al DISCO DURO
o grabacion en AVI , MPEG .
Instale en una computadora DELL de Escritorio
bien actualizada todo , pero no graba y sale para Internet
puedo mesclar y todo pero no grbar que es lo mas importante
envie el codeigo de error via el soft + capturas adjuntas .
Gracias en espera de su ayuda
#2 Posted : Friday, November 25, 2011 10:23:25 PM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
This means the graphics card does not support recording, you will need to install a dedicated graphics card.
ELCHAPIN
#3 Posted : Saturday, November 26, 2011 3:48:39 PM(UTC)
ELCHAPIN
thanks
that easy is the problem.
well I'll tell you to buy it.
Install a DEMO on the computer of them.
if you are interested to accommodate the equipment
HAPPY DAY OF ACTION D E THANKS
FOR ALL
Gracias
asi de facil es el problema .
bueno les dire que lo compre .
Instale un DEMO en la computadora de ellos .
si les interesa que acomoden el equipo
FELIZ DIA DE ACCION D E GRACIAS
PARA TODOS
