Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
Hello I have problems mistakenly saved to hard disk or recording in AVI, MPEG. Install DELL Desktop computer well updated everything, but does not record and goes to Internet I can blend and everything but grbar which is the most important codeigo send the soft error + via the attached screenshots. Thanks waiting for your help ================================================================== Hola tengo problemas por error de guardado al DISCO DURO o grabacion en AVI , MPEG . Instale en una computadora DELL de Escritorio bien actualizada todo , pero no graba y sale para Internet puedo mesclar y todo pero no grbar que es lo mas importante envie el codeigo de error via el soft + capturas adjuntas . Gracias en espera de su ayuda
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4788 time(s) in 1643 post(s)
This means the graphics card does not support recording, you will need to install a dedicated graphics card.
Martin vMix
thanks that easy is the problem. well I'll tell you to buy it. Install a DEMO on the computer of them. if you are interested to accommodate the equipment HAPPY DAY OF ACTION D E THANKS FOR ALL
Gracias asi de facil es el problema . bueno les dire que lo compre . Instale un DEMO en la computadora de ellos . si les interesa que acomoden el equipo FELIZ DIA DE ACCION D E GRACIAS PARA TODOS
