Running vMix and Watching FB stream causes CPU warning!
Joined: 6/6/2020(UTC) Posts: 34  Location: NC Thanks: 11 times
I have a laptop that only runs vMix and only use it to stream to Facebook. If I'm only watching the stream in vMix by the IP camera,everything is fine. If I watch the IP camera stream and FB,then I get a high CPU warning. The laptop has a Ryzen 3200U,8gb ram and vega 3 graphics. I'm running the stream at 1080p.
I thought that the Laptop would have been fine,but now I'm wondering if I should look into another laptop or a PC build. Unless,there is a setting that I'm missing. Any input is appreciated. Thanks
vMix is optimized for NVDIA graphics, whereas AMD Radeon is not recommended.
The Ryzen 3200U is not a very robust CPU. If all is fine without watching the IP camera stream and Facebook, then it would be best to do that.
Originally Posted by: SportsNetUSA.net  vMix is optimized for NVDIA graphics, whereas AMD Radeon is not recommended.
The Ryzen 3200U is not a very robust CPU. If all is fine without watching the IP camera stream and Facebook, then it would be best to do that. That's what I do. I start the stream and then view FB to make sure things are ok,then stop the FB stream. Got any suggestions on a Laptop/Desktop that would work? I have seen the guide for various builds,but I'm wondering if they would be more than I need since I'm only doing one 1080p stream and watching the FB stream. If I can find a Laptop or SFF PC that would work for the Church,then that would be great.
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Your VMix computer should be 100% dedicated to VMix. Most of the streaming platforms are buggy and will grind computers to a halt while VMix is running.
