Vinicius
#1 Posted : Saturday, October 17, 2020 10:35:21 PM(UTC)
Vinicius
Brazil
Hello everyone!
Today I am doing Stream on 3 different channels, YouTube, Twitch and Facebook.
On YouTube and Twitch I'm using the highest quality in 1080p, being:
Youtube and Twitch: 1080p 6mbps 320kbps
Facebook: 720p 2.5mbps 320kbps
However after I start the 3 lives I receive a message on the YouTube channel saying that my upload is at 1773 mbps, stating that my viewers will face buffering, being that I am 6mbps and my internet does not present any type of problem, in addition, the YouTube recommends I make a change to the keyframe frequency, from 2 to 4 frames per second, however
I did not make this change in the settings.
Yesterday carrying out some tests I lowered my upload level of the 6mbps twitch to 2.5 mbps, and Facebook and YouTube I kept the same upload rate, after that YouTube had no more problems and I had excellent status all the test transmission I did .
I need help to solve this, I know it is not my internet and it is not my computer either because the use of cpu / gpu is at a good level. Could it be a bug?
PC config: i7-8700K GTX 1060 32GB Ram with SSD
My internet has an average of 700mbps download and 500 mbps upload
I thank you all and I am waiting for help.
Thank you very much
Vince Beck
#2 Posted : Sunday, October 18, 2020 5:06:14 AM(UTC)
Vince Beck
AFAIK, it's a YouTube bug, did you actually see issues on YouTube playback?
Vinicius
#3 Posted : Thursday, October 22, 2020 11:11:09 AM(UTC)
Vinicius
Brazil
hello vince, thanks for the reply!
I also believe that it is a bug, but when I download the amount of upload that I use on the twitch, from 6 mbps to 2.5 mbps, the low upload message that youtube shows disappears!
I didn't see any problems with the image or sound quality. However seeing that youtube message I was intrigued.
a friend of mine uses 6mbps on youtube and 6 mbps on twitch and 2.5 mbps 720p and his internet has an average of 250 mbps upload, half of mine.
finally
