Joined: 10/17/2020(UTC) Posts: 2  Location: Santa Catarina
Hello everyone! Today I am doing Stream on 3 different channels, YouTube, Twitch and Facebook. On YouTube and Twitch I'm using the highest quality in 1080p, being:
Youtube and Twitch: 1080p 6mbps 320kbps Facebook: 720p 2.5mbps 320kbps
However after I start the 3 lives I receive a message on the YouTube channel saying that my upload is at 1773 mbps, stating that my viewers will face buffering, being that I am 6mbps and my internet does not present any type of problem, in addition, the YouTube recommends I make a change to the keyframe frequency, from 2 to 4 frames per second, however I did not make this change in the settings.
Yesterday carrying out some tests I lowered my upload level of the 6mbps twitch to 2.5 mbps, and Facebook and YouTube I kept the same upload rate, after that YouTube had no more problems and I had excellent status all the test transmission I did .
I need help to solve this, I know it is not my internet and it is not my computer either because the use of cpu / gpu is at a good level. Could it be a bug?
PC config: i7-8700K GTX 1060 32GB Ram with SSD
My internet has an average of 700mbps download and 500 mbps upload
I thank you all and I am waiting for help. Thank you very much
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
AFAIK, it's a YouTube bug, did you actually see issues on YouTube playback?
hello vince, thanks for the reply! I also believe that it is a bug, but when I download the amount of upload that I use on the twitch, from 6 mbps to 2.5 mbps, the low upload message that youtube shows disappears! I didn't see any problems with the image or sound quality. However seeing that youtube message I was intrigued.
a friend of mine uses 6mbps on youtube and 6 mbps on twitch and 2.5 mbps 720p and his internet has an average of 250 mbps upload, half of mine. finally
