Joined: 10/17/2020(UTC) Posts: 1   Location: Zielonka Thanks: 1 times
I want to set the title so that it will come over the video clip (30 min) after 10 minutes (600000ms). Unfortunately, Delay only allows a delay of up to 30 seconds, despite the setting of 600000ms. Is it possible to do?
Rank:: Advanced Member
Joined: 7/17/2020(UTC) Posts: 59  Location: Makati City Thanks: 11 times Was thanked: 5 time(s) in 5 post(s)
Unfortunately, you can only do a workaround with timers as the trigger delay only works with a max of 30 seconds.. Set up a timer with a 10 minute countdown and set a trigger in your video OnTransitionIn start countdown. Then set up a trigger in your countdown: OnCompletion Overlay1in with input being the title you want to overlay Good luck
 1 user thanked Martin Block for this useful post.
Joined: 3/30/2020(UTC) Posts: 17   Location: Leran Thanks: 14 times
If you want to create a longer delay and are prepared to live with the risk of odd consequences, you can set a trigger to Set Volume of the Input to 100% (where it probably is anyway) after 30,000 milliseconds, and then put another trigger with a delay of <30,000 milliseconds, or if you need to, repeat the Set Volume trigger. In the first instance, the 'real' trigger will activate after 30,000 + however many milliseconds you specify. If you keep adding 30,000 millisecond fake delays, remember that you may get odd, unexpected triggers occurring later on.
