Waran3
#1 Posted : Saturday, October 17, 2020 8:27:29 AM(UTC)
Waran3
Rank:: Newbie
Poland
I want to set the title so that it will come over the video clip (30 min) after 10 minutes (600000ms). Unfortunately, Delay only allows a delay of up to 30 seconds, despite the setting of 600000ms. Is it possible to do?
Martin Block
#2 Posted : Saturday, October 17, 2020 9:44:13 AM(UTC)
Martin Block
Philippines
Unfortunately, you can only do a workaround with timers as the trigger delay only works with a max of 30 seconds..
Set up a timer with a 10 minute countdown and set a trigger in your video OnTransitionIn start countdown.
Then set up a trigger in your countdown: OnCompletion Overlay1in with input being the title you want to overlay
Good luck
thanks 1 user thanked Martin Block for this useful post.
Waran3 on 10/19/2020(UTC)
clibil
#3 Posted : Saturday, September 24, 2022 11:09:29 PM(UTC)
clibil
If you want to create a longer delay and are prepared to live with the risk of odd consequences, you can set a trigger to Set Volume of the Input to 100% (where it probably is anyway) after 30,000 milliseconds, and then put another trigger with a delay of <30,000 milliseconds, or if you need to, repeat the Set Volume trigger. In the first instance, the 'real' trigger will activate after 30,000 + however many milliseconds you specify. If you keep adding 30,000 millisecond fake delays, remember that you may get odd, unexpected triggers occurring later on.
