Preset H.264 Video 6Mbps, Audio 128Kbs is using twice the bandwidth
I am monitoring my expensive router which displays real-time bandwidth usage by my pc during live stream & it shows bandwidth being used for upload stream as 11.80Mbps. With my settings it should be around 6.2Mpbs. Is it normal?
Joined: 7/23/2013(UTC) Posts: 122 Location: North Thanks: 12 times Was thanked: 13 time(s) in 11 post(s)
Originally Posted by: e.belyshev I am monitoring my expensive router which displays real-time bandwidth usage by my pc during live stream & it shows bandwidth being used for upload stream as 11.80Mbps. With my settings it should be around 6.2Mpbs. Is it normal? You have probably checked that you are not streaming two same destinations instead of a single one? Sometimes it's easy to just start streaming with the direct button which starts both (or all) streams at once. With "use stream 1 quality" it will use up about twice the bandwidth.
