e.belyshev
#1 Posted: : Thursday, October 15, 2020 6:26:32 PM(UTC)
e.belyshev
I am monitoring my expensive router which displays real-time bandwidth usage by my pc during live stream & it shows bandwidth being used for upload stream as 11.80Mbps. With my settings it should be around 6.2Mpbs. Is it normal?
jip
#2 Posted : Friday, October 16, 2020 12:09:26 AM(UTC)
jip
Estonia
You have probably checked that you are not streaming two same destinations instead of a single one?
Sometimes it's easy to just start streaming with the direct button which starts both (or all) streams at once. With "use stream 1 quality" it will use up about twice the bandwidth.
