Feature Requests
Using inputs on multiple tabs
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
I've never really worked that much with the tabs, but since my productions are getting more and more complicated, I would like to put some order into it.
The problem I have with the tabs is that I can't put inputs on mulitple tabs.
The first tab should still be all inputs with all the "garbage" in it
But I would like to create setups for different purposes, but would like to put some inputs in multiple tabs...so that I can always see them.
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Oh and it would be also great if we could put the inputs on the tabs in different orders without messing up the main tab.
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
+1 I think it would very helpful if we could assign inputs to multiple categories
Joined: 8/16/2017(UTC) Posts: 25 Location: Lafayette IN
Was thanked: 8 time(s) in 3 post(s)
Joined: 10/14/2020(UTC) Posts: 12  Location: Toronto Thanks: 8 times
+1
Manually sorting inputs per tab helps bring order to complex shows.
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
+1
And it would be a really good thing if you could activate 2 or 3 tabs simultaneously.
Feature Requests
