Rinsky
#1 Posted : Monday, September 28, 2020 9:00:31 PM(UTC)
Rinsky
I've never really worked that much with the tabs, but since my productions are getting more and more complicated, I would like to put some order into it.
The problem I have with the tabs is that I can't put inputs on mulitple tabs.
The first tab should still be all inputs with all the "garbage" in it
But I would like to create setups for different purposes, but would like to put some inputs in multiple tabs...so that I can always see them.
MickeyMJJ
#2 Posted : Tuesday, September 29, 2020 12:04:10 AM(UTC)
MickeyMJJ
I posted a similar subject but never got a response
https://forums.vmix.com/.../t18031-Input-categories
Rinsky
#3 Posted : Wednesday, September 30, 2020 10:37:51 AM(UTC)
Rinsky
Oh and it would be also great if we could put the inputs on the tabs in different orders without messing up the main tab.
Video Dave
#4 Posted : Wednesday, September 30, 2020 5:08:58 PM(UTC)
Video Dave
+1
I think it would very helpful if we could assign inputs to multiple categories
cgarwood
#5 Posted : Thursday, October 1, 2020 9:56:42 PM(UTC)
cgarwood
Was thanked: 8 time(s) in 3 post(s)
+1
CamStol
#6 Posted : Wednesday, October 14, 2020 10:50:06 PM(UTC)
CamStol
Canada
+1
Manually sorting inputs per tab helps bring order to complex shows.
Gunnar
#7 Posted : Monday, October 26, 2020 5:48:34 AM(UTC)
Gunnar
Sweden
+1
And it would be a really good thing if you could activate 2 or 3 tabs simultaneously.
