ahoravision
#1 Posted : Wednesday, July 16, 2014 10:58:21 PM(UTC)
ahoravision
I have registered two copies of vMix HD we use for a semi-profesional broadcasting setup. You can see the quality of the work we do here:
https://ahoravision.com/ahora-en-directo-live/
I think we have found a limitation that is kind of impacting our workflow, I want to see if you can help us. Again, its a limitation, not a bug or a problem with the software.
The limitation I found is that I'm only allowed to output to a single Display device. I am aware that vMix is capable of 4 simulateneus outputs (File, Render, Display and Streaming) but in our setup we need a multi-display setup. Is this possible? I want a display in Fullscreen with the live output and another display with the Multi-View for the director to use.
Any workaround and/or suggestions?
Thanks,
ask
#2 Posted : Thursday, July 17, 2014 1:07:20 AM(UTC)
ask
That is available in vMix4k
ovinas
#3 Posted : Thursday, July 17, 2014 1:07:41 AM(UTC)
ovinas
You need the 4K Edition of version 13. Then you have two fullscreen outputs.
http://forums.vmix.com.a....aspx?g=posts&t=2333
See the first Major New Feature.
