Output to multiple displays
Hi, I have registered two copies of vMix HD we use for a semi-profesional broadcasting setup. You can see the quality of the work we do here: https://ahoravision.com/ahora-en-directo-live/I think we have found a limitation that is kind of impacting our workflow, I want to see if you can help us. Again, its a limitation, not a bug or a problem with the software. The limitation I found is that I'm only allowed to output to a single Display device. I am aware that vMix is capable of 4 simulateneus outputs (File, Render, Display and Streaming) but in our setup we need a multi-display setup. Is this possible? I want a display in Fullscreen with the live output and another display with the Multi-View for the director to use. Any workaround and/or suggestions? Thanks,
Joined: 10/13/2012(UTC) Views messages in topic : 1,159  Location: Melbourne Thanks: 221 times Was thanked: 200 time(s) in 181 post(s)
That is available in vMix4k
