rinaldo
#1 Posted : Friday, September 25, 2020 5:15:39 PM(UTC)
rinaldo
Hi guys, I need to setup a room for 2 commentators. What equipment are you using to import 2 audio feeds from the headsets?
How the commentators can hear eachother, adjust phones volume indipendently, etc
Thanks!
x422man
#2 Posted : Wednesday, September 30, 2020 10:32:16 AM(UTC)
x422man
i have 2 commentators together in the same commentary booth, using a laptop with vMix HD and Focusrite Scarlett 8i6 USB Mixer. it has 2 independent headphone outputs with separate level control, and option to direct monitor inputs on the headphones. so no delay hearing themselves.
they are remote so they grab feed using SRT from another vMix workstation and push commentary back again using SRT. they watch on Fullscreen using 2nd laptop HDMI output and have that fed into 2 monitors through a hdmi splitter (DA). so they can distance themselves from each other.
if i was to need to do this more local, i would use NDI instead of SRT to reduce the latency. but it works great.... only issue i have ever had is with the hdmi splitter, but that s hdmi for you, just a digital version of scart...
hope this helps
x422man
bar807
#3 Posted : Saturday, November 19, 2022 12:47:58 AM(UTC)
bar807
With the scarlett 8i6, will each individual input show as a separate input on vMix? And will the scarlett 4i4 (since cheaper) do the job for 2 commentators as per your setup? I need to do setup for 2 commentators
https://www.amazon.de/-/...i4%2Cmi%2C105&sr=1-2
bar807
#4 Posted : Saturday, November 19, 2022 12:48:29 AM(UTC)
bar807
hope this helps
x422man
Guest (4)
Similar Topics
Headsets for commentators generating Noise (General Discussion)
by bar807 8/7/2023 11:18:01 PM(UTC)
Commentators setup (General Discussion)
by rinaldo 3/5/2022 12:50:47 AM(UTC)
COVID emergency solution - Commentators for a Football Game (vMix Call)
by tgdzapa1 9/4/2020 9:09:24 PM(UTC)
USB gaming headsets for live commentators with VmixCall (vMix Call)
by tgdzapa1 2/11/2020 10:39:27 PM(UTC)
