Hi Everyone:
I have a windows 10 machine and I noticed that every time I "restart" or "shutdown" my computer and then launch vMix, my main webcam settings are not kept and I have to go into the camera itself, and readjust.
Is there a setting that I can tick or save that keeps it how it is and doesn't require me to reset it each time I open the program??
Greg
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
Start vmix Add the webcam Make the adjustments Safe this as a preset.
Next time start vmix. Do not load the webcam but load the webcam preset you have saved. I
Originally Posted by: Pepsi(~)  Start vmix Add the webcam Make the adjustments Safe this as a preset.
Next time start vmix. Do not load the webcam but load the webcam preset you have saved. I I do that already...It just happens when I restart or power all the way off. If I close the program and then fire it back up without the power cutting, it's fine...
what I read is that you do a recovery of the preset. that was active on the last moment. What I suggest is to save the webcam configuration. and instead of recovery. load it. you can merge it if you have a second preset. already loaded.
Joined: 3/17/2017(UTC) Posts: 454  Location: Luzern - Schweiz Thanks: 69 times Was thanked: 58 time(s) in 52 post(s)
