bbqcentralshow
#1 Posted : Thursday, September 24, 2020 10:56:20 PM(UTC)
bbqcentralshow
Hi Everyone:
I have a windows 10 machine and I noticed that every time I "restart" or "shutdown" my computer and then launch vMix, my main webcam settings are not kept and I have to go into the camera itself, and readjust.
Is there a setting that I can tick or save that keeps it how it is and doesn't require me to reset it each time I open the program??
Greg
Pepsi(~)
#2 Posted : Friday, September 25, 2020 5:03:54 AM(UTC)
Pepsi(~)
Netherlands
Start vmix
Add the webcam
Make the adjustments
Safe this as a preset.
Next time start vmix.
Do not load the webcam but load the webcam preset you have saved.
I
bbqcentralshow
#3 Posted : Friday, September 25, 2020 10:56:02 AM(UTC)
bbqcentralshow
Originally Posted by: Pepsi(~) Go to Quoted Post
Start vmix
Add the webcam
I
I do that already...It just happens when I restart or power all the way off. If I close the program and then fire it back up without the power cutting, it's fine...
Pepsi(~)
#4 Posted : Friday, September 25, 2020 4:41:56 PM(UTC)
Pepsi(~)
Netherlands
what I read is that you do a recovery of the preset. that was active on the last moment.
What I suggest is to save the webcam configuration. and instead of recovery. load it. you can merge it if you have a second preset. already loaded.
elvis55
#5 Posted : Friday, September 25, 2020 7:19:29 PM(UTC)
elvis55
Views messages in topic : 456
Switzerland
