Hi folks, embarrassed that I can't find the simple thing I am looking for after hours of searching and watching.
I am sure I don't yet understand the syntax of the Value:Index portion of shortcuts. The Knowledge base references it but I can never make sense of it. I have a Ph.D. which means I'm only smart in one area. :-) It's not this one.
Trying to set a shortcut to turn off or toggle on and off Multiview overlays in an input.
Can someone describe the way the Value: works when the Function is MultiviewOverlay (which should be toggling) when selected?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
The index refers to the ordered number of the layer in this example the 4th layer of input 8-colour (the input itself is 0 )  mvovl.JPG (39kb) downloaded 2 time(s).
