Doc Haskell
#1 Posted : Tuesday, September 22, 2020 3:48:56 AM(UTC)
Doc Haskell
Hi folks, embarrassed that I can't find the simple thing I am looking for after hours of searching and watching.
I am sure I don't yet understand the syntax of the Value:Index portion of shortcuts. The Knowledge base references it but I can never make sense of it. I have a Ph.D. which means I'm only smart in one area. :-) It's not this one.
Trying to set a shortcut to turn off or toggle on and off Multiview overlays in an input.
Can someone describe the way the Value: works when the Function is MultiviewOverlay (which should be toggling) when selected?
#2 Posted : Tuesday, September 22, 2020 5:45:11 AM(UTC)
The index refers to the ordered number of the layer
in this example the 4th layer of input 8-colour (the input itself is 0 )
