phab
#1 Posted : 5 years ago
phab
Can you show status of a vmix call, like this exemple ?
Call disconnected
Best regard,
Phab
omnisound
#2 Posted : 5 years ago
omnisound
Hi all !
Good suggestion ! It will be a good feature.
Loïc (from France)
Aecast
#3 Posted : 5 years ago
Aecast
Was thanked: 10 time(s) in 7 post(s)
+1 and would be great to reflect the status is the api xml as current only says "running" be better to have connected and disconnected
Paul Camino
#4 Posted : 5 years ago
Paul Camino
The call manager window has this feature. calls in red are disconnected. Its not on the multiviewer but this window easily pops out and you can place it on another screen, or different area within the single screen if that's what you use.
call manager.png (82kb) downloaded 0 time(s).
polsten
#5 Posted : 5 years ago
polsten
Germany
I go with Paul Camino...
If you have a vMixCall, open the Callmanger on an seperated Monitor.
Then you can see the status of all your calls.
Also click on the icon in the top left with red,yellow,green Bars to open more options like bitrates of audio and video from your Callers.
tracecomplete
#6 Posted : 4 years ago
tracecomplete
+1
I don't have enough screen real estate to dedicate a window to the Call Manager. It ends up backgrounded somewhere and I have to go find it when we're switching speakers.
This should totally just be part of the multiview/input picker.
