Feature Requests
Show status of a vmix call
Hello, Can you show status of a vmix call, like this exemple ?  Best regard, Phab
Joined: 3/19/2011(UTC) Posts: 28   Location: France Thanks: 1 times
Hi all ! Good suggestion ! It will be a good feature.
Loïc (from France)
Joined: 3/25/2020(UTC) Posts: 48  Location: Chichester Was thanked: 10 time(s) in 7 post(s)
+1 and would be great to reflect the status is the api xml as current only says "running" be better to have connected and disconnected
Joined: 6/5/2020(UTC) Posts: 55  Location: California Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
The call manager window has this feature. calls in red are disconnected. Its not on the multiviewer but this window easily pops out and you can place it on another screen, or different area within the single screen if that's what you use.  call manager.png (82kb) downloaded 0 time(s).
I go with Paul Camino...
If you have a vMixCall, open the Callmanger on an seperated Monitor. Then you can see the status of all your calls.
Also click on the icon in the top left with red,yellow,green Bars to open more options like bitrates of audio and video from your Callers.
Joined: 11/16/2019(UTC) Posts: 12  Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
+1
I don't have enough screen real estate to dedicate a window to the Call Manager. It ends up backgrounded somewhere and I have to go find it when we're switching speakers.
This should totally just be part of the multiview/input picker.
Feature Requests
