Vmix has restarted into Mandarin?
Joined: 6/16/2020(UTC) Posts: 3  Location: Essex Thanks: 1 times
So... this is weird and a pretty bad bug. I was changing output 1 audio bus from Master to Bus B Vmix then asked to restart, it has restarted into mandarin or some variation similar. I've since restarted the machine, and opened other shows and still not changing. Anyone able to help? See below  Chinese.png (92kb) downloaded 2 time(s).
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Settings -> Options : change language
You must have done something else unknowingly as that change does not require a restart
Ah thanks, that makes more sense. Will try and find it!
