carlito
#1 Posted : Wednesday, August 19, 2020 12:55:54 AM(UTC)
carlito
Jamaica
Hi all. I wanted to create a solution where a remote presenter can click through their slide using internet clicker and then simple have the vmix call UI and the buttons on one page. Once I embed the vmix call page however I cannot get camera or mic access in any browser. Seems the embedded site needs to explicit allow. Anyone knows of a way to get this setup?
Screenshot
simond83
#2 Posted : Wednesday, August 19, 2020 12:15:45 PM(UTC)
simond83
tsioukas
#3 Posted : Monday, August 24, 2020 6:00:11 PM(UTC)
tsioukas
Greece
Unfortunately frameset and iframe doesn't allow to use WEBRTC.
I think the best option is VMIX team to create an API so we can use their platform on our sites with html/javascript. And API that can pass ID/Name from our fields it will be useful.
newmans
#4 Posted : Tuesday, August 25, 2020 12:38:04 AM(UTC)
newmans
Germany
you need to add allow="camera;microphone;" to the iframe
Code:
<iframe src="https://beta.vmixcall.com/" frameborder="0" allow="camera;microphone;fullscreen" allowfullscreen=""></iframe>
Regarding the API
Originally Posted by: DWAM Go to Quoted Post
There is a "partial" workaround for this: you can create a webpage on your website with your own logo and have a form that vMixCallers use to type their name and key before being redirected to the vMixCall service. It is a partial workaround because when the guest disconnects it shows the vMixCall logo anyway. So it's only half a solution.
Here's a piece of code for the landing page on your website (there are several ways to do this, this one is just a copy and paste from another thread on the forum, not my code)
Code:
<!-- Script -->
<script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js"></script>
<script type="text/javascript">
$(document).ready(function(){
$('#vmixform').submit(function(){
var urlNumber = $('#vmixNumber').val()
var urlName = $('#vmixName').val()
var urlString = urlNumber + "&Name=" + urlName
window.location = "https://www.vmixcall.com/call.aspx?Key=" + urlString;
return false;
</script>
<!-- For the text fields in HTML body -->
<input type="text" class="form-control" id="vmixName" placeholder="Name" name="vmixName" required>
<input type="text" class="form-control" id="vmixNumber" placeholder="Password vMix Call" name="vmixNumber" required>
thanks 1 user thanked newmans for this useful post.
tsioukas on 8/26/2020(UTC)
carlofornasari
#5 Posted : Tuesday, August 25, 2020 3:18:33 PM(UTC)
carlofornasari
Screenshot
Has anyone got this working yet? Tring to get interent clicker and vmix call in the same window with no luck so far
newmans
#6 Posted : Tuesday, August 25, 2020 4:06:02 PM(UTC)
newmans
Germany
See my Post above, there is everything you need to add to the iframe of vmixcall.
And be sure you have an SSL certificate working in the webpage.
tsioukas
#7 Posted : Wednesday, August 26, 2020 10:15:47 PM(UTC)
tsioukas
Greece
Code:
Thank you, thank you and again thank you... i didn't know that, you save me from a lot of research time.
Lynchee
#8 Posted : Monday, November 9, 2020 10:20:27 PM(UTC)
Lynchee
did anyone get this to work?
newmans
#9 Posted : Wednesday, November 11, 2020 4:17:11 AM(UTC)
newmans
Germany
yes, it´s running several months now
Guest (10)
