vMix Call
Embedding Vmixcall.com in to my website?!!
Thanks: 2 times Was thanked: 2 time(s) in 1 post(s)
Is there a way to embed vmix call into my site with out the vmixcall logo showing?
thanks
Martin you can earn more money from this!! People are very interested :) Very happy to pay a yearly fee for a white label vMix Call with custom URL.
Joined: 6/12/2020(UTC) Posts: 7  Location: New York Was thanked: 1 time(s) in 1 post(s)
Joined: 7/4/2020(UTC) Posts: 5  Location: Sao Paulo Was thanked: 1 time(s) in 1 post(s)
Joined: 4/1/2020(UTC) Posts: 5  Location: Ronse Thanks: 1 times
There is a "partial" workaround for this: you can create a webpage on your website with your own logo and have a form that vMixCallers use to type their name and key before being redirected to the vMixCall service. It is a partial workaround because when the guest disconnects it shows the vMixCall logo anyway. So it's only half a solution. Here's a piece of code for the landing page on your website (there are several ways to do this, this one is just a copy and paste from another thread on the forum, not my code) Code:<!-- Script -->
<script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js"></script>
<script type="text/javascript">
$(document).ready(function(){
$('#vmixform').submit(function(){
var urlNumber = $('#vmixNumber').val()
var urlName = $('#vmixName').val()
var urlString = urlNumber + "&Name=" + urlName
window.location = "https://www.vmixcall.com/call.aspx?Key=" + urlString;
return false;
</script>
<!-- For the text fields in HTML body -->
<input type="text" class="form-control" id="vmixName" placeholder="Name" name="vmixName" required>
<input type="text" class="form-control" id="vmixNumber" placeholder="Password vMix Call" name="vmixNumber" required>
Joined: 7/5/2019(UTC) Posts: 28  Location: Sydney Was thanked: 5 time(s) in 4 post(s)
thanks +1
Originally Posted by: DWAM  There is a "partial" workaround for this: you can create a webpage on your website with your own logo and have a form that vMixCallers use to type their name and key before being redirected to the vMixCall service. It is a partial workaround because when the guest disconnects it shows the vMixCall logo anyway. So it's only half a solution. Here's a piece of code for the landing page on your website (there are several ways to do this, this one is just a copy and paste from another thread on the forum, not my code) Code:<!-- Script -->
return false;
</script>
I'm a bit of an HTML rookie. How exactly do I submit the info and run the script for that once I've implemented the HTML element to my site? I've added a submit button but doesn't seem to do anything. I've not worked with scripts before. (Still learning)
Joined: 10/10/2019(UTC) Posts: 65   Location: Düsseldorf Thanks: 5 times Was thanked: 17 time(s) in 10 post(s)
Hey, just make a button with the type="submit". Then the button will run the above Function. Quote:<form id="vmixform"> <input type="submit" value="YourButtonText" class="btn btn-default"> </form> regards
 1 user thanked Follo for this useful post.
vMix Call
