stevewaski
#1 Posted : Monday, August 10, 2020 7:54:35 AM(UTC)
stevewaski
I’m doing remote live-streaming with a Teradek VidiuGo and am trying to figure out how to get the signal out (including audio) of vmix on my laptop to the VidiuGo unit.
Can I use my HDMI out to go directly to the VidiuGo or do I need some sort of external card?
dmwkr
#2 Posted : Wednesday, August 12, 2020 2:57:10 AM(UTC)
dmwkr
That is basically possible, it is mentioned as one of the possibilites for the Full Screen output in Tim's video:
stevewaski
#3 Posted : Wednesday, August 12, 2020 4:25:45 AM(UTC)
stevewaski
Totally understand that part — but not sure how to get the audio to output as well? Will it go with the full screen output or do I need to set that up separately?
dmwkr
#4 Posted : Wednesday, August 12, 2020 4:35:44 AM(UTC)
dmwkr
When you plugin your device to the HDMI output, there will appear a new audio output in Windows, and thus in vMix. You have to select it as Master in Settings, Audio Outputs.
