halfpipe
#1 Posted : Saturday, November 12, 2011 1:00:34 PM(UTC)
halfpipe
Hi all
-I'm an ole school videographer (just read old)
-Firewire DV switching ..finally put it all together for 4 cameras then decided I needed HDV for which no devices were within range .
-now I've a bunch of hdmi camcorders and have been editing using the multicam function in edius. I do expect to pick up a bit of business if I can stream Televison quality video and vMix might just be the ticket.
-What about teradek cube? I don't see that under the capture tab.
-Have a Sony HDRFX7 via HDV firewire on the screen, mixed with a CX550v via intensity shuttle on the screen. Seems to mix although the firewire lag issue might be a stopper.
If I were to put a system together are 3 intensity pro cards the way to go?
#2 Posted : Sunday, November 13, 2011 8:33:55 AM(UTC)
The recommended setup is 2 or more intensity pro cards for HDMI sources or a DeckLink Quad for SDI sources.
For the Teradek Cube, you can purchase both an Encoder and a Decoder to plug in to to an Intensity Pro or DeckLink card.
Note that the latency can be quite high and the quality is limited but it should work.
