Joined: 11/27/2017(UTC) Posts: 17   Location: Louisville, Kentucky Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
I am familiar with vMix shortcuts and have used them often. I am new to datasource use and can not get these shortcuts to work. I have included 3 examples. looking for advice on getting these shortcuts to work.  ex1.PNG (64kb) downloaded 2 time(s). ex2.PNG (56kb) downloaded 2 time(s). ex3.PNG (57kb) downloaded 1 time(s).
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 230 time(s) in 130 post(s)
Names are case-sensitive. For next-row you should use For select row name and table should be the same, and Row parameter - is number of row from zero. You can see what API command UTC send in the log file. You also should write questions about UTC into UTC thread.
 1 user thanked elgarf for this useful post.
Thank you for the help. In the future I will post UTC questions in the UTC thread.
 1 user thanked timbrian for this useful post.
