timbrian
#1 Posted : Sunday, August 2, 2020 11:49:41 AM(UTC)
timbrian
I am familiar with vMix shortcuts and have used them often. I am new to datasource use and can not get these shortcuts to work. I have included 3 examples. looking for advice on getting these shortcuts to work. ex1.PNG (64kb) downloaded 2 time(s). ex2.PNG (56kb) downloaded 2 time(s). ex3.PNG (57kb) downloaded 1 time(s).
elgarf
#2 Posted : Sunday, August 2, 2020 2:42:36 PM(UTC)
elgarf
Russian Federation
Was thanked: 230 time(s) in 130 post(s)
Names are case-sensitive.
For next-row you should use
Code:
Excel/CSV,Sheet1
For select row name and table should be the same, and Row parameter - is number of row from zero.
You can see what API command UTC send in the log file.
You also should write questions about UTC into UTC thread.
thanks 1 user thanked elgarf for this useful post.
timbrian on 8/3/2020(UTC)
timbrian
#3 Posted : Monday, August 3, 2020 6:45:58 AM(UTC)
timbrian
Thank you for the help. In the future I will post UTC questions in the UTC thread.
thanks 1 user thanked timbrian for this useful post.
elgarf on 8/3/2020(UTC)
