jjbutler83
#1 Posted : Wednesday, July 29, 2020 11:33:08 AM(UTC)
jjbutler83
Was thanked: 4 time(s) in 1 post(s)
System.Runtime.InteropServices.COMException (0x88890008): Exception from HRESULT: 0x88890008
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at vMixDesktopCaptureLibrary.WASAPICapture..ctor(WASAPIAudioDevice dev)
at vMixDesktopCaptureLibrary.WASAPIAudioProvider.Create(AudioDevice d)
at vMixDesktopCaptureLibrary.DesktopCaptureServer._AudioThread()
Windows 10 Pro Build 1909 - logged in as an admin and running Desktop Capture with Admin privileges.
All drivers up to date.
jjbutler83
#2 Posted : Thursday, July 30, 2020 1:34:28 AM(UTC)
jjbutler83
Finally solved the issue myself.
Was this box in Sound properties that was ticked and so when I unticked it vMix Desktop Capture began working:
thanks 4 users thanked jjbutler83 for this useful post.
tomtailford on 11/11/2020(UTC), Haitham on 1/9/2021(UTC), Filipebranco on 3/11/2021(UTC), JakePie on 6/23/2021(UTC)
RichShumaker
#3 Posted : Friday, October 6, 2023 8:40:16 AM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
This Error occurs also when you have an audio feedback loop inside the PC.
I was sending audio with NDI Webcam as well as Voicemeeter and causing an internal feedback loop when I used vMix NDI Desktop Capture.
Once I removed the loop the error went away.
Weird part - Video works just fine you just do not have audio.
