NDI
NDI Desktop Capture (PC) error after loading
Joined: 7/29/2020(UTC) Posts: 8  Location: Florida Was thanked: 4 time(s) in 1 post(s)
System.Runtime.InteropServices.COMException (0x88890008): Exception from HRESULT: 0x88890008 at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at vMixDesktopCaptureLibrary.WASAPICapture..ctor(WASAPIAudioDevice dev) at vMixDesktopCaptureLibrary.WASAPIAudioProvider.Create(AudioDevice d) at vMixDesktopCaptureLibrary.DesktopCaptureServer._AudioThread()
Windows 10 Pro Build 1909 - logged in as an admin and running Desktop Capture with Admin privileges. All drivers up to date.
Finally solved the issue myself. Was this box in Sound properties that was ticked and so when I unticked it vMix Desktop Capture began working:  Capture.PNG (41kb) downloaded 12 time(s).
 4 users thanked jjbutler83 for this useful post.
Joined: 4/4/2016(UTC) Posts: 236  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
This Error occurs also when you have an audio feedback loop inside the PC.
I was sending audio with NDI Webcam as well as Voicemeeter and causing an internal feedback loop when I used vMix NDI Desktop Capture.
Once I removed the loop the error went away.
Weird part - Video works just fine you just do not have audio.
NDI
