Livemike
#1 Posted : Tuesday, July 21, 2020 10:26:13 AM(UTC)
Livemike
Hi everyone thanks you for the assistance in advance
so I am new to ndi
I just want to use the technology to send graphics from one pc to the streaming pc both with vmix
can u tell me which cheap network switch will allow this ?
mavik
#2 Posted : Tuesday, July 21, 2020 8:37:51 PM(UTC)
mavik
Netgear is a good vendor. Mikrotik is cheap as well but comes with a ton of options which I won't recommend as a novice.
Livemike
#3 Posted : Tuesday, July 21, 2020 9:58:38 PM(UTC)
Livemike
thanks for the reply can you give me a model number
mavik
#4 Posted : Tuesday, July 21, 2020 10:10:35 PM(UTC)
mavik
I don't know what you are looking for but maybe some exmples
Netgear
unmanaged: GS105v5
Soho: GS305v3
Cloud Managed: GS108Tv3
Mikrotik
RB260GS
Google is your friend. It's not complicated really. Just lazy letting others check.
