Hi everyone thanks you for the assistance in advance
so I am new to ndi I just want to use the technology to send graphics from one pc to the streaming pc both with vmix can u tell me which cheap network switch will allow this ?
Joined: 4/23/2017(UTC) Posts: 1,454  Location: Germany Thanks: 3 times Was thanked: 192 time(s) in 172 post(s)
Netgear is a good vendor. Mikrotik is cheap as well but comes with a ton of options which I won't recommend as a novice.
thanks for the reply can you give me a model number
I don't know what you are looking for but maybe some exmples Netgear unmanaged: GS105v5 Soho: GS305v3 Cloud Managed: GS108Tv3
Mikrotik RB260GS
Google is your friend. It's not complicated really. Just lazy letting others check.
