robert5521
#1 Posted : Saturday, July 18, 2020 4:34:03 AM(UTC)
robert5521
Spain
Was thanked: 7 time(s) in 4 post(s)
I would like to make elaborated multiview animations like this:
I do my composition in photoshop with the rectangle of the speakers as a transparent crop. And then I put this over the inputs (vmix calls) but when I transition using the "Merge" I get a crossfade effect I don't like:
mergeeffect]https://ibb.co/f4PSqGW]mergeeffect
Also, how can click the input and make it to program instead of preview like the previous video?
Thank you very much!
Martin Block
#2 Posted : Thursday, August 13, 2020 10:19:51 AM(UTC)
Martin Block
Philippines
The tutorial you showed is really a nice example.
After watching it, I believe that the merge transition duration was shortened so you cannot see the crossfade effect that you do not like.
Also, if you go to settings/options/Activate QuickPlay by clicking Preview Window
You can change the click behaviour (please see vMix user guide)
Hope this helps
Cheers
#3 Posted : Thursday, August 13, 2020 4:15:17 PM(UTC)
each input layout has ALL the same inputs in multiview and then one merges between them.
If you do get a sort of crossfade one has to temporary switch the layer order of these inputs in the multiview (trigger)
like Martin says : quickplay for selecting view
