How can I replicate these multiview effects?
Joined: 6/1/2020(UTC) Posts: 27  Location: Spain Thanks: 1 times Was thanked: 7 time(s) in 4 post(s)
I would like to make elaborated multiview animations like this: I do my composition in photoshop with the rectangle of the speakers as a transparent crop. And then I put this over the inputs (vmix calls) but when I transition using the "Merge" I get a crossfade effect I don't like: mergeeffect]https://ibb.co/f4PSqGW]mergeeffectAlso, how can click the input and make it to program instead of preview like the previous video? Thank you very much!
Joined: 7/17/2020(UTC) Posts: 59  Location: Makati City Thanks: 11 times Was thanked: 5 time(s) in 5 post(s)
Hi, The tutorial you showed is really a nice example. After watching it, I believe that the merge transition duration was shortened so you cannot see the crossfade effect that you do not like.
Also, if you go to settings/options/Activate QuickPlay by clicking Preview Window You can change the click behaviour (please see vMix user guide)
Hope this helps
Cheers
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
each input layout has ALL the same inputs in multiview and then one merges between them. If you do get a sort of crossfade one has to temporary switch the layer order of these inputs in the multiview (trigger)
like Martin says : quickplay for selecting view
